Reply
Highlighted
can i earn referral reward by buying another sim card with another plan?
Accepted Solutions
Highlighted
GR
Re: can i earn referral reward by buying another sim card with another plan?
@publicly  yes  as many as you like, just use  your referral code when activating!
All Replies
Highlighted
GR
Highlighted
@publicly hi yes you will get 1 dollar per 30 day cycle and your new account will get  10 dollars added to that account
Highlighted
@publicly  Access your selfserve account and on the top right of the page is your referral code. Provide that code during the activation on the new PM sim card and you will get the reward. Please note that the code might contain both zeroes and/or the letter O so make sure you enter it correctly otherwise it will not work.
Highlighted
Yes ... but remember that once your 2nd sim card's plan lapses, your reward for that will discontinue too ...
Highlighted
Sure you can! Just be sure to use your referral code when you setup the sim card.
Highlighted
This question was a answered multiple times about more than half a day before you.  Please take a moment to go through threads before deciding to post.  This will help to avoid repitition. Thanks.
Highlighted
Yes, as long as you activate the SIM card and have a plan.
Highlighted
This questions has been aswered multiple time more than a week ago.  Please try not to repeat others.  This will help message thread becoming unnecessarily long, which sometimes tends to make it hard for people to find answers.
