Why are my reward $ not applied?
Milk
Have just noticed on my credit card statemen that the monthly charges for my PM auto pay  account are $16.95 even though I'm entitled to reward discounts. Cut and pasting rewards shown on my account page.
    • Loyalty Reward ($1)
    • AutoPay Reward ($2)
    • Community Reward $0
    • Refer-a-Friend Reward ($1)
What gives?
7 REPLIES 7
Staliger
What gives?
@Milk if you disagree with your bill, and your rewards were not applied, contact moderators who can help: click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
What gives?
Which plan do you have?
Check your payment history from your overview page.
Please note that your cc payment is higher with the sale tax added to your monthly plan fee less rewards.
If you have a $15 plan and you are from ON, your rewards were not applied.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
Tell Simon does not appear on my page.
I think he means the balloon itself. It's very intermittent for me. At this typing it's not there.
popping
Enter "Your reward were not applied during renewal"
@Milk to get to Simon the autobot.  Click on the green questionmark in the white circle at the bottom right of your screen.
Milk
What gives?
Good luck.
pirabaa31
when did you activat the account? all the rewards applied after 30 days, check your current balance. should be your balance $4 next month auto pay charge only $16.95
popping
What gives?
$15 * 13% tax = $16.95
Good luck.
