Reply
Re: Who can earn Rewards?
@dboxtvinfo wrote:
I can
Yes, we know.  Everyone with a non-grandathered/legacy account can.
@dboxtvinfo wrote:
What happens if I am using old account for login ? I have passed the 90 days and activated a new sim card.
I don't understand the question.  You waited 90 days and then activated a new sim card?  Why?  Confused.
@dboxtvinfo wrote:
I do find text packs expensive.
This is completely off topic for rewards.  However, the text packs are actually FREE if you select a talk and a data option.  On any 30 or 90 day plan, pick ANY talk option (other than no talk) and ANY data option (other than no data) and try switching between no text and global text.  You will notice that the discount goes up by the same amount as the texting option, making the price the same with or without texting.  I think FREE is pretty reasonable, so I disagree with your statement.
So I've been a customer with PM since December 2012.... I still wouldn't be eligible for rewards for that?.....
@lilyjayde if you're still on your legacy plan from back then, then no you are not eligible for rewards.  If you've switched to one of the newer pick-and-pay plans more recently, then you would be.  But you'd also lose phone-based support, if that's important to you.
@lilyjayde
However if you switch to a new plan, you'll get the loyalty reward as soon as you make the switch.
http://productioncommunity.publicmobile.ca/t5/Announcements/NEW-Talk-and-Text-Promo-Plan/m-p/156225#...
That's great info @Someone_here
I am with public mobile since 3 years but I never get any award, no discount.
Tags (1)
@syed51, what is your current plan? How much for what service?
If you haven't changed plan since 3 years, you most probably are on a grandfathered/pionner plan, which doesn't allow for rewards.
If you want, you can call 611 and ask them to change plan for one of the current plans.
Keep in mind:
- You'll gain $2/month reward, if you use autopay
- you'll gain $3/month reward, if you have been clients t for 3 years.
- You'll lose access to the call center, then the only way to get assistance will be through this forum.
- Depending of your current plan, you'll probably pay less afterward.
@syed51 I think @Someone_here is 100% correct here. If you are still on your original plan from 3 years ago, those plans are not eligible for rewards.  Only the newer "pick and pay" plans are.  You would need to change plans in order to qualify for rewards.  This may or may not be beneficial for you, depending on what you're currently paying and getting from your grandfathered "legacy" plan (the plans prior to the pick-and-pay system).
i love it that plan Heart
you getting Talk Unlimited
Get your talk on!
Here is what you get:
$20/30* days Unlimited Province-wide1 Talk
30-day plan on Canada’s largest mobile network
Voicemail and Call Display
Heart
Keep in mind.
you haven't changed plan or you can't changed your plan just add your on 90 day to you can get all this Reward from public mobile , see it at
https://www.publicmobile.ca/en/on/plans .
you can call *611 and ask them to change plan for one of the current plans. you like it .
If you want it to changed your plan, to you have to put your plan for on 90 day and your get a awesome Reward .
when you change your plan , You'll lose access to the call center *611, then the only way to get assistance will be through this forum. or you can send private messages to special agent .
Depending of your current plan, you'll probably pay less afterward and you will get a discount and all Reward from public mobile .
GOOD LUCK  Heart
