Reply
Highlighted
Switching Plans rewards question
Hi,
New poster here, if this is in the wrong section I apologize.
I'm currently on a basic unlimited text+call, 1GB plan, and recently came across a promotion of $40 for 4GB.
What I'm wondering is, with my current plan I have $4 off on rewards. If I switch to this upgraded plan, will I lose my current rewards or do they carry over regardless?
Cheers,
J
Accepted Solutions
Highlighted
Re: Switching Plans rewards question
@j112 wrote:
Hi,
Cheers,
J
The rewards are tied to the account, not the plan. So, no you won't loose the rewards if you switch plans.
Just a hint: Unless you are running out of data before the end of your term, you want to do a future dated plan change.  There are no refunds for unused parts of your current plan if you switch immediately.
All Replies
Highlighted
@j112 wrote:
Hi,
Cheers,
J
Highlighted
To add on, I believe it’s actually 5gb for $40, so even better!
Highlighted
@luke11992
Yes..its 4.5 gb and if you add autopay it brings it up to 5 gb....for 50$ with autopay you get 8.5 gb...just remember what was mentioned earlier if you do an immediate plan change you will lose whatever was left of your previous plan,no credits or refunds for the unused days.
Highlighted
your rewards are linked to the existing account
Highlighted
Thanks,
