Reply
Referral
Is there a way to see who you referred to Public Mobile? I've been telling everyone I see about Public and would like to know who switches.
GR
Re: Referral
If you log in to your account and click on my rewards and double click on the the little triangle next to friend refferal it will show you all the phone numbers of people that used your refferal number
Re: Referral
Go into your self serve account, click on my rewards, click on the little arrow. You should be able to see the referal numbers you have there.
Re: Referral
Hi @hellsbells05 , if you login to the self-serve (My Account) and clicking on the Plan and Add-Ons tab and selecting the Rewards tab, you can see the Refer-a-friend Reward. Below that, you can see the list of phone number/s you referred.
Re: Referral
Tags (1)
