Referral 1GB add-on being used before data from plan
HickTrick
Hey there,
I was recentaly awarded the one time 1GB add-on reward for a referral.
Looking at this thread here:
https://productioncommunity.publicmobile.ca/t5/Rewards/Refer-a-Friend-Reward-1GB-free-data/m-p/19754...
The second post suggests that the 1GB add-on only startes getting used once your allotment of data has reached it's max, and I also read that anything unused from the 1GB will carry over month to month.
However, looking at my account overview, I see that the 1GB addon has some(a small amount) of it's data used up already, even though I have plenty left in my 12GB of data from my plan. Is this a glitch? Or was that post I'm referring to incorrect?
Data & Add-OnsAmount Used
12GB Data
1437.196  /  12288 MB
1GB Referral Add-on
22.825  /  1024 MB
Thanks,
Paul
2 REPLIES 2
Gimli
I am not sure if this is a problem that needs to be "fixed" manually for every account until such time of the back end logic has been resolved.  re-adding the addo will indeed "fix" the used data issue... until it starts drawing down again.  Very strange issue though....
NDesai
@HickTrick Yes, that is the case for the referral add-on but it doesn't suppose to work like that. They are already aware and currently investigating. You should send a private message to the Moderator_Team with your account info and they will fix it manually.
