Reply
Highlighted
Refer a friend
I need to know the phone numbers which used my phone number as referral.
Tags (1)
Highlighted
Re: Refer a friend
I believe a moderator would be able to provide that info.
Moderator can be reached at
Highlighted
Re: Refer a friend
It's visable click the my rewards button in overview page then expand the total rewards earned under plan cost title
Highlighted
Re: Refer a friend
Log in to self-serve, scroll down and click on My Rewards, click on the little right kinda arrow, it opens up those rewards listing the phone numbers that you referred.
Edit: ninja'd by mimmo 🙂
Highlighted
Re: Refer a friend
@Triguy  yes mods can provide that but if is easily available to customers as noted above.
Highlighted
Re: Refer a friend
It does not show the phone numbers
Highlighted
Re: Refer a friend
Check with those referrals to see if they're still active with PM. That little arrow can be a bit dodgy to click. It should open up to all your rewards.
Highlighted
Re: Refer a friend
It does show the amount which I earned through referral but not the numbers which I referred.
Highlighted
Re: Refer a friend
You will need to click on it to expand the referal rewards section to see the numbers
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click the "?" in the bottom right to create a trouble ticket *
Highlighted
Re: Refer a friend
@Goelvini The moderators should not be providing this information, as it is confidential if you don't see it yourself.  In the rewards tab, you will see all the numbers that you have referred to join Public Mobile.
You will not see who you have been referred by.
