Planning join PM again. Anyone can send me a referral code? So we both get discounts!
fsm7268
Is it $10 or $25 now?
LovesToPM
Not sure if this is an issue. If you plan on using the same email as last time, need to know if there is a waiting period before you are eligible for the referral reward again.
Of course activating with a new email and new number means no issue with old phone number / old account.
geopublic
Current $10 as others have mentioned above. Also, you won't be able to use your old PM SIM so you would need to purchase a new one.
Pizzaeh
Whether to wait or move to Public Mobile now depends on what are you paying and what is included in your plan with your current carrier.  If you're paying close to what you would pay for a similar plan with Public Mobile, then you might as well wait for the next promotion.  Also factor in any cancellation/tab fees for hardware you may have purchased from your current carrier.
hairbag1
There's currently no promotions active, so unless you're in a hurry...wait for a bit. Usually don't have to wait long for the next one to come around.
Makes it interesting though. Good luck and welcome to Public Mobile.
Lieux
It's only 10$ for you and 1$ per month for the person who referred you. And if it's again....you need to activate a new sim card with a new number phone.
