06-19-2020 06:25 PM - edited 01-05-2022 12:14 PM
Hello, is there a maximum number for the refer a friend reward or you can refer as many as you can and earn the 1$ per month reward each referrals?
06-19-2020 07:20 PM - edited 06-19-2020 11:47 PM
06-19-2020 07:17 PM
There's no maximum referrals but there is only one maximum_gato here. If you have more than one account or family then you may want to switch referral codes as you get close to covering your plan. Keep in mind there's up to $5 in loyalty the longer you stay so you may want to keep that open if you have other accounts that you are paying for and start using their referral codes.
06-19-2020 07:07 PM
Awesome. I thought there was a maximum. Thanks for the answers!
06-19-2020 06:43 PM
@buang99 , no need to put all the eggs in one basket. If you are going to be a referral magnet, then put them in different accounts.
06-19-2020 06:36 PM - edited 06-19-2020 06:38 PM
@buang99 wrote:Hello, is there a maximum number for the refer a friend reward or you can refer as many as you can and earn the 1$ per month reward each referrals?
Go crazy, dude...get as many as you want. The max rewards that can be applied to your account are whatever your plan costs are.
06-19-2020 06:34 PM
@buang99 There is no limit for referrals.
