I have a question
Chels22
I referred my dad to public mobile, i few hours ago, and it said I'd receive a one-time credit of $20, and he will get a $10 credit for using my referral code,when do you see the credit, like how does that work?
sunflowershine
@Chels22 Normally you as referrer will receive a text from PM that you are successfully referred a friend. As others said, the reward will be given within 72 hours.
It should be within 72 hours.
hairbag1
As a Public Mobile customer you need to:
  1. Be a good pal and refer a friend to Public Mobile.
  2. Tell your friend that they need to successfully activate online or in-store on any plan during the promotional period and include you as their referrer in order to be eligible for the promotion. Learn more about Referral Codes HERE
  3. The extra one-time $20 credit will be applied to your Self-Serve account within 72 hours of your friend’s activation. In addition, you will continue to be eligible for the $1 referral credit off your monthly bill for as long as your friend stays with Public Mobile.
