How do I turn on auto renewal
Bradleypaul
CaptainisCaptai
You will have to go under payment on your table and choose Enroll in the Auto PAY
Sarlye
Your plan auto renew per month as its a Prepaid account.
You can either set up Auto Pay which gives you $2 or have enough amount to pay your monthly bill and your account will auto renew each month.
Please see the other community member on how to set up AutoPay.
Cheers!
Triguy
If you are asking about autopay - here is more info.
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
