11-04-2019 05:51 PM - edited 01-05-2022 09:38 AM
Hey i am trying to earn some community points to put towards a plan I want
I HAVE 26.00 AND I NEED 50.00, CAN ANYBODY HELP ME OUT PLZ
02-05-2020 11:28 AM
That's good to know. Thanks!
@Anonymous wrote:Oracle's exist by invite only. Short of that, the best us mere mortals can do is $15.
02-05-2020 11:17 AM
02-05-2020 11:07 AM
I agree with you. I think it is not easy to reach an Oracle level which needs to post a lot of answers in a timely manner.
@rhbcc wrote:like what the abovementions said earning a $20 reward towards an oracle status is doable but will require most of your time and effort (not very feasible if you have a full time job). there are other ways to earn rewards to lower your bill and other streams of income so you can pay for the plan you are eyeing.
02-04-2020 10:50 PM
11-04-2019 11:08 PM
@MissPidasso Rather than continuing to repeat myself. Check out the following threads to get lots of insight on the community rewards. Top Contributers-September 2019, Re:Rewards as well as you can either type community rewards in the search bar for other posts on this topic and/or browse the rewards section and scan thru the titles for ones relating earning rewards in the community or other categories.
11-04-2019 06:33 PM
@MissPidasso as noted by @Anonymous, the most anyone but the current crop of oracles can earn in a calendar month for community rewards is $15, and doing that requires a TON of time and effort. Trust me, I'm on here way more than I should be an the past sevearl months I've only been hitting the $5 or $10 level.
I think you may need to find an alternative source of revenue, or look at a cheaper plan. The $25 plan, for example, is pretty popular.
11-04-2019 06:19 PM
Here's the rewards program from the PM knowledge base.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/General-Reward-Rules/ta-p/164
