Community rewards
Barnes99
Hi there all. Hope you are all safe and self isolating. My question is exactly how do I earn community points? I don’t get it. Thanks
13 REPLIES 13
aliaksar2000
Thanks for the response. I am just curious how this works since I mentioned it to a friend who is interested in switching to Public Mobile and reducing her bill by helping the community. Another question, please? How much time you spend to help roughly and how much you get?
hi @aliaksar2000
No, there is no minimum.  We do not know the exact formula PM uses
I think just like when you do any good thing, keep doing and don't think about rewards  🙂
But honest, if you spend 10 mins for 2 nights a week.  Reply what you can.  Bravos posts that you like.  You can easily get $1 or $2 for the month.   Getting $5 or $10 would be harder.  $15 would require you be a FULL TIME SUPPORT staff here.  🤣
aliaksar2000
Yes but how exactly? Is there any minimum number of poss to make, or Bravo to get, or posts marked as Solution?
Annoying_Orange
To earn community rewards you can
1. Answer questions and helping others out on the community.
2. Be active and participate in the community.
3. Contribute and get involved with the community.
4. *Bonus: Also depending on how long you stay as a Public Mobile costumer  can also earn up to $1/30 days for each year you’re with Public Mobile up to $5/30 days.
depending on your level of involvement with our Community, you can earn up to $20 every 30 days. The amount you are rewarded depends on your contribution level relative to overall contribution. Just note that You can only qualify for one Community Reward in a 30-day period, and you must act in accordance with Community Terms of Service at all times.
Heres the Terms of service on rewards and how to earn them: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Public-Mobile-Community-Terms-of-Servi...
Have a great rest of your day! Hope it helps you
fdrcamb519
This is a good answer
fdrcamb519
I’m new, myself, but from what I’ve been reading, is get involved, in the community, ask questions, answer, questions, reply, give bravos etc....I’m only a few days in with public mobile, but this is what I got so far, maybe someone can add to this...,,,
Dylan3
You get community reward points by contributing to posts and asking questions
ddeep91
@Barnes99
You get community rewards by helping other people by answering questions that are being asked just like this one.  You can also read about the rewards HERE.
I also recommend  Checking out/reading all these Knowledge Base. about  PM. It will help you understand and learn more about the company if you are looking to start helping other customers.
Cheers
Staliger
@Barnes99 in short, understand how PM system works, and help people who have problems/questions regarding service.
By responding to questions posed by customers and if good and right that customer and others might click Bravo for your contribution. Then that customer might choose your reply as the solution. Then early each month you might see an amount in your rewards area that will go towards your plan cost at your next renewal.
Then do it all over again because the reward resets each month.
popping
@Barnes99
Start by spending time(lots of it) reading and learning how PM system works.  Then helping member to solve their problem.
geopublic
@Barnes99  Click here for more info. And here.
