Hello,
I have been a long time customer with PM for a while, if we change the phone plan, are we eligible to get the rewards on the monthly invoice? please advise.
Thank you
@Ththng1 wrote:Hello,
Thank you
Yes all plans are eligible. It gets a little messy with 90 days or 30 days but you're still entitled.
Are you a legacy customer? If so, I think you are not eligible for rewards on your current plan. But if you switch to an in-market plan, you would be eligible for autopay, loyalty, and community rewards.
Hello,
Thank you for your prompt response.
You are welcome.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
@Ththng1 as stated yes you can switch to any plan and you will become eligable for rewards. You will likely start with 3$ loyalty.
To switch you need to call 611 and confirm you want to switch as you will lose 611 call support.
@slash407, legacy and pioneer subscribers are *required* to contact 611 to make the change. They are asked to confirm they understand that they are switching away from a plan that has voice support, and moving to the online-only support system.
