Reply
Re: AutoPay Reward
Ok, i just want to understand the way it works, and hopefully it'll make it easier for others.
I did sign up for the credit card payments that will be taking out certain amount out of my account every month. Now, $2 credit thing? it's just gonna continue adding to my account? i mean it'll be 2 years before i can actually do something with it really.
Or can it be used for add-ons? Right?
Re: AutoPay Reward
@Litvinau_A,
The credit of 2$ is added to your balance each month.
You can use to pay an addon or your prepaid plan.
Re: AutoPay Reward
OK, but if i'm getting an exact amount withdrawn from my credit card every month? How will it know to withdraw $2 less?
But i can definitely use it for add-ons.
Tags (1)
Re: AutoPay Reward
@Litvinau_A,
When you want to use your balance, you have to lower the amount taken from your credit card (auto-pay).
Re: AutoPay Reward
@Cyber
Thanks a Lot! I'm sure i'll figure it out once i have more $$ to play with.
Re: AutoPay Reward
i have activated yr service and my payment is done auto now i have not received $2 rebate everymonth
pal
Re: AutoPay Reward
I'm not certain WHEN the Auto-Pay Rewards is Applied exactly
Re: AutoPay Reward
The money from Auto-Pay Rewards ($2/month), Refer-A-Friend Reward plus any other Rewards like the Community Bravos points that accumulate in your Balance will be used to pay towards your bill first before the remaining amount gets charged to your credit card that you've added as Auto-Pay. Hope that helps
Re: AutoPay Reward
When does the autopay credit apply for 90 day plans?
Retraité / Retired
Re: AutoPay Reward
Hello @Jonavin,
If you are registered for Autopay, you will receive the rewards upon the renewal of your plan.
The system will deduct the rewards from the cost of your plan, and add the difference to your account to renew your plan.
Cheers Smiley Happy
Kalla
