$2 reward for autopay
nicoldans
Hello!
i ned to know if the 2$ reward for auto pay also applies to the plans where you get the 500mb bonus for autopay...basically if you have autopay you get both bonusses ($2 off and 500 mb extra)?
thanks
Both are yoursel to keep until..
tony7
Yes, you get the $2 reward and the bonus 500MB as well.
Koyabtx
Yup that's correct, you'll get both rewards/bonuses. I'm currently on the $25 1GB w/ autopay and got both the 500mb and the $2 for autopay 🙂
markevee
Yes that is correct, you get both, $2 off and the additional data.
sunflowershine
@nicoldans wrote:
Hello!
thanks
@nicoldans Yes. Once you set up as autopay, you will get $2 reward after the charging your account in the payment cycle even you don't make any payment if you have other rewards to cover your monthly plan. $25 plan will have 500 mb extra on the 500 mb in the plan itself. So you have 1 GB instead as long as you have autopay set up in your account.
ShawnC13
@nicoldans wrote:
Hello!
thanks
Yes if you have picked one of the plans with the 500mb autopay bonus you will get that as well
