Sims cards
fairchse
Where can you buy them in Yarmouth NS where you can activate them yourself
@Bettycaligiuri wrote:
If you can wait a week for shipping, I recommend buying your SIM from amazon. I bought mine from there and it worked perfectly when I went to set it up. They are on sale right now for $6.99! Here is the link: https://www.amazon.ca/Public-Mobile-Card-Unlocked-Phones/dp/B07R6P5KBB/ref=mp_s_a_1_3?keywords=publi...
They also include a referral code that will save you $10
Hope you get your SIM card soon! Smiley Happy
Please click the 3 dots on top right of your post and edit the post to remove the referral code you posted. It's against the terms of public mobile forums to post referral codes
Bettycaligiuri
They also include a referral code that will save you $10 OR you can use someone's referral code and also save $10 plus give them a referral bonusSmiley Very Happy
fairchse
Wow your from Yarmouth, You know I tell a lot of people how much money I save but they are intimidated by the online resolution
What I find is that once you get used to the navigation of the site it’s a lot quicker to deal with issues online than being bounced around on the phone
GR
@fairchse go to the superstore! I'm from Yarmouth and most times Walmart won't sell them without activating them
will13am
@fairchse, try using this store locator.  Might be worthwhile to call ahead also.  Some Walmart locations have been known to only sell SIM cards to those who activate in store.
https://www.publicmobile.ca/en/on/store-locator
