Refer a friend code not entered
Cbouc
I just went to Walmart to sign my wife onto PM. The phone salesman was rude. He just asked for a email adress, new pin and postal code. Before I know-it the acount was activated, before I had a chance to give him my referral code. He said there is nothing he can do, not even cancel the account. Is there a way I can get my referral code to wife' account, for her to receive a $10 credit and I receive $1 less per month? Her account was activated about 15 minutes ago.
7 REPLIES 7
SURYA547021
File a ticket with customer support, they will fix it.
pkaraa
open a ticket by contacting CSA or click on the blurb in the bottom right.
It will be faster.
@Cbouc wrote:
Thanks.
I do not remeber my 4 digit pin.
@Cbouc
you will say forgetting and they will Reset for you,
update @Cbouc
or you can open Here link  and enter your community username and password,
Cbouc
Thanks.
@Cbouc   There is a chance that PM Customer Support will be able to apply it back for you.
Simply open a ticket with PM and hope for the best.
To open a ticket with Customer Support Agent, click on the Bubble or directly at : https://publicmobile.ca/chatbot
Enter your question in SIMon. Follow the prompts until you reach the Contact Us button,
If you have problems submitting a ticket, you can also send a private message to CS_Agents (but this can take longer):
Please open a ticket by going to https://widget.telus.tiia.ai/publicmobile/publicmobile.html . After going there and opening a ticket, you'll need to explain this situation to the customer support agent.
@Cbouc
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
they will Add for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
  • you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck....
