04-17-2020 07:14 PM - edited 01-05-2022 10:25 AM
04-19-2020 07:54 AM
@Cw111 Did this start happening after your most recent renewal? Try these two troubleshooting techniques they might get rid of the annoying message.
Otherwise the moderators can fix this glitch that pops up occasionally. If your renewal is only a few days away you could wait til after your renewal. Chances are your renewal will reprovision your account and get rid of the message.
04-18-2020 10:18 AM
Does it just say it bit the call goes through?
That means today you are no longer using 1 in front of the number, if you are annoyed by the message just put 1 in front of the number
04-18-2020 12:18 AM
Thank you for all your help!
04-17-2020 10:52 PM
@Cw111 wrote:I would to speak to a moderator. Do you have a phone#?
There is no phone number.
To receive assistance:
Please use the chatbot SIMon to help you solve your issue. If SIMon cannot solve your issue then you have the option to contact a moderator.
Step 1: Choose the ? button at the right bottom corner of this page or choose “Get Help” at the top of the page and then choose the “Chat with SIMon” button.
Step 2: Tell SIMon what the issue is and see if he can find a solution for you.
Step 3: If Simon cannot find a solution then type in “moderator” to connect to a Public Mobile customer service representative.
Step 4: Simon will present you with two choices. Choose “Account-specific question”
Step 5 Then choose “No, I want a human”
Step 6 Create your ticket
Check the sent folder to make sure your ticket was sent (envelope icon, top right) and the inbox for a reply from the moderators.
“To ensure the safety of our team members during the COVID-19 pandemic, our Moderator team is working at reduced levels. During this time, you may experience longer than normal wait times when contacting our Moderator team for help.”
Moderators are available:
Monday to Friday from 8 AM to midnight Eastern time.
Saturday and Sunday from 8 AM to 10 PM Eastern time
04-17-2020 10:47 PM
04-17-2020 10:44 PM
Thx but I am making the same calls as before but now it mentions every call is long distance.
04-17-2020 09:59 PM - edited 04-17-2020 10:02 PM
@Cw111 have you spoken to a moderator yet? what does the plan say on the top side of the bill?
04-17-2020 09:54 PM - edited 04-17-2020 09:55 PM
@Cw111 if you are on a unlimited provincial wide plan, and try to call someone outside of the province you would get that message. Adding the 500 minute Canada wide addon for $5 would allow you to do it. Never expires, stays on your plan until used up and also would only be used when calling long distance.
Please check your number and redial it. Thanks.
04-17-2020 09:54 PM
04-17-2020 09:49 PM - edited 04-17-2020 09:53 PM
@Cw111 wrote:Yes something is not right. I have not moved and it says "you do not have an active long distance plan" i purchased it at London Drugs.
@Cw111 yes when it say's that it usually means you are on the old 10 or 15 dollar plan and you have run out of minutes you really should speak to a moderator find out what is going on
04-17-2020 09:49 PM
purchased May 2019
The msg says " You do not have an active long distance add-on. This call is not covered by your plan" I have not moved to need long distance. Thx for your help.
04-17-2020 09:44 PM
04-17-2020 09:39 PM
04-17-2020 08:36 PM - edited 04-17-2020 08:43 PM
04-17-2020 07:47 PM
@Cw111 wrote:Ok but using someone else’s phone and not home right now. My email jammed trying to use from my phone but if can try again today or tomorrow will take photo for you to post. Thx.
If you're plan is out of calling minutes and you need to call....consider getting the aforementioned 500 Canada wide calling add-on for $5. Any unused add-on minutes will roll over until you use them up...even if it takes several months or longer to do so.
04-17-2020 07:46 PM
04-17-2020 07:42 PM
04-17-2020 07:40 PM
Thank you for all responses. I appreciate the feedback.
04-17-2020 07:40 PM
@Cw111 wrote:I have the receipt and plan details at time of purchase
Could you please take a photo and post it here. We can surely give you guidance if there's a problem.
04-17-2020 07:37 PM
04-17-2020 07:34 PM
@Cw111 wrote:They should inform people then that it is a limited promotion. And this is Telus.
Whatever plan you originally signed up for...you still have ...as long as you didn't change it yourself.
04-17-2020 07:33 PM
Have the receipt.
04-17-2020 07:32 PM
04-17-2020 07:32 PM
@Cw111 wrote:thankyou. Plan purchased unlimited province wide $15 June 2019 not a promotion.
Log into My Account ...then look at Plan Details to see what plan you actually have currently.
04-17-2020 07:31 PM
Whatever you see in the plan details tab is what you have now. There is no going back.
04-17-2020 07:29 PM
04-17-2020 07:29 PM
@Cw111 wrote:Less than one year ago
I don't believe there has been a plan that cheap with unlimited minutes last year. The older $15 plan was not unlimited incoming minutes whereas the current one is.
04-17-2020 07:29 PM - edited 04-17-2020 07:30 PM
@Cw111 the $15 plan is unlimited incoming not outgoing, outgoing is 100 minutes. The $25 plan is unlimited outgoing. You can buy a 500 minute, $5 addon from within your self service account. It never expires and stays on your account until used up. Heres an article on buying add ons.
https://www.publicmobile.ca/en/on/get-help/articles/purchase-add-ons-through-self-serve
To save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and you are in your voicemail account - Hang up when you are finished. No minutes used
OR
You can change your plan. It's recommended that you cjange on the next renewal date. Heres an article on switching plans https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan
Use the screenshot below on where to do it.
Stay safe
04-17-2020 07:27 PM
That plan is no longer available. The current $15 plan is 100minutes of Canada wide calling.
04-17-2020 07:26 PM
