Dropped calls
Michele74
I was hooked up today and my phone kept dropping the calls
why does this happen
robertmay
there has been a temporary network problem on Telus towers recently.  I am in Alberta and have had the same issue today.  They are aware of it and it should be rectified asap.   Have an awesome day.
geopublic
My understanding that the entire Telus/Kood/Public Mobile network is experiencing some issues out West and hopefully it will be resoved shortly.
If you need to get a hold of the Moderator Team just click here The link sends you to the private message function and adds the moderator team as recipient for a private message.
You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Alex888
@Michele74 Are you in a bad reception area? Try toggling Airplane mode on and off, see if that helps.
