Cancelling Service on Lost Phone
julley
I lost my cellphone on Friday, I need to know the following:
1. How do I cancel the service
2. I need a new SIM card, and also need to keep the same phone number
Julley
mimmo
@julley. Did you try using the find my device feature?  Also you should be able to wipe the phone remotely.  and as a final step I would report it lost I think the mods can do that for you so it goes on the blacklist.  ( if you don't have the imei, I was told in a previous post the mods can still blacklist a phone without it.)
@jeffster1970 Last half of you post is correct. There is no need for moderator intervention for the issue as described.
ShawnC13
@julley, there is no need to cancel.  You can login to your self serve and go to plan and addons and there is a tab for lost of stolen phone.
lost.PNGOnce you purchase a new sim you would come back to this page and unsuspend your service then go to Change SIM.  This way you keep your same phone number
julley
thanks @jeffster1970
jeffster1970
Julley
Hi there -- sorry for your loss -- you'll need to PM the @CS_Agent to help you with all that.  Just explain the same thing you explained here.  Alternatively, I do believe you can go and purchase a new SIM card from Wal*Mart and just change SIM numbers (in the user portal), and your phone number will be the same, and the other SIM will be de-activated.
