Reply
Highlighted
Account
I can’t login to my account. Help you please
Accepted Solutions
Highlighted
Re: Account
@Kevincoote
Have you tried to reset your password?
https://selfserve.publicmobile.ca/forgot-password/
(Check your spam folder)
If does not work, you will need to contact moderator.
Send a private message to moderator through the following link :
All Replies
Highlighted
Re: Account
Does the log on page load.
Do you get an error message?
Try using a browsers incognito mode.
You can try the forgot password option.
Highlighted
Re: Account
@Kevincoote
Highlighted
Re: Account
I’m trying to reset my password but I also forgot what email I used?
Highlighted
Re: Account
@Kevincoote
You may need to check your various email accounts.  Usually, when you activated your account, you would have received a welcome email from Public mobile.
Highlighted
Re: Account
You can try each of your emails in the forgot password portion. Do this one at a time. The emails to reset your password might take a little bit of time.  So do that and wait maybe half an hour?
Not sure if this will work.  You can try setting up a new account option on the right side.  You might be able to use your current email and make a new self serve account.
Or you could contact the moderators. This might take upto 3 days.
Highlighted
Re: Account
@YVR  last time I tried this the system would either say invalid email or take me to the verification questions
@Kevincoote if you need to pay you can try 611 if you have a credit card registered and you know your pin, or you can buy a voucher and top up that way.
