wrong add on purchase, is there a way to fix it?
fireboltt
Hello,
I'm currently in the US and tried to purchase the US 10 days roaming add on using self serve, but by mistake i purchased the 200 minutes Canada to US minutes,.
is there away to replace the US 200 minutes add on with the US roaming one, they both have 8$ cost.
geopublic
@fireboltt wrote:
Hello,
@fireboltt since you are in the US just purchase the correct US roaming addon to get up and running and then send a message to the moderator for a refund.
fireboltt
thanks for your help
Triguy
Contact a moderator for assistance.
Send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
GinYVR
@firebolttPer term of service is all add ons are non refundable.. however the 200 minutes add on does not expire until you had consumed it.
