us roaming differed date
Nikita
Hello.  Is there a way to prepay the add on and ask it to start at a certain date.  I am leaving on the 29th for 16 days and need two add ons back to back.
also i have add on data but will my data work out of province ie in another province
If you can get by on WiFi alone, another option is to use an app such as Fongo.  You could forward your phonenumber to the Free Fongo number you'll create, and use it to answer and make calls back to Canada.
In conjunction, You could use the conbination US talk/txt/data addon, or get the data only, and txt only addons while you're there, and use the Fongo app over the data roaming.
jp2
I am not aware of a feature that allows purchasing the roaming package and starting at different dates.
Your data Addon will work in other provinces but not the us
mimmo
Data works anywhere in Canada.
As for the usa roaming you can activate it in the USA by dialing the 1800 number,you just need to have a credit card on file and know your pin number.
Info found here. https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Learn-all-about-US-Roaming/ta-p/75772
