"Bonus" data
Suzie
So I just jumped on 9 + 3 GB bonus plan (up from the 6 GB plan - great timing as I needed more data and my renewal date is today!), but I'm not clear on what it means that some of the data is a bonus.  Can I expect to get 12 GBs every 90 days for as long as I keep the plan or will it drop to 9 at some point or...?
cricketfan
The bonus will be there till you change your plan. It's just a different way of wording it
@Suzie wrote:
That really doesn't make sense to me because PM is advertising it as 4GB (/mth) for $45(/mth), which is 12 GB/ 90 days.  If the plan dropped back down to 9GB at the next renewal, that would, instead, be 3GB/mth.
It makes sense that the bonus data sticks around for a while; I just wasn't sure if it was time limited in some way.
Sorry, my bad. My brain connected to the pricing before the 4GB/$45 promo, when most 90day plans had a bonus addition.
Same answer though - as long as you don't change your plan you'll keep the 12GB/$141/90days (before rewards).
The time limit is re signing up before the eventually communicated end date.
Suzie
wetcoaster
Your 9GB (per 90days) are renewing as long as you don't change the plan.
MoreYummy
Bonus is basically the promotion.  So you have more data than normal plan data allowance.
