question about $15 plan
arunaralhan
$15 plan says 100 minutes canada wide and unlimited incoming calls. Does that mean that minutes are only deducted from 100 minutes for out going calls?
8 REPLIES 8
Nexzen
Yes, only on outgoing. Incoming minutes should all be free so let your buddies know to call you instead by text 🙂
cvuong324
correct!
@Think wrote:
100 minutes are our outbound calls,while incoming is unlimited
This is only true for the "new" version of the $15 plan. There are two versions of this plan: For a couple of weeks when the plan was first introduced it was offered as 100minutes of combined incoming and outgoing minutes. This was later changed to 100minutes outgoing and unlimited incoming. If you are on the first version of this plan you need to manually future date the change for the next renenewal date to take advantage of the unlimited incoming minutes.
Think
@dabr wrote:
Yes and you can add 500 Canada wide minutes for only $5 that will stay with your account until totally used up for even greater value.
That is like an insurance policy. If suddenly you are needing to make more outbound calls than normal, rather than suddenly having outbound service just stop working you would begin to consume minutes from the $5/500 minute add on. If you use 50 of them up and then your plan renewal you are back to working from the included 100 minutes in your plan and the remaining 450 minutes in the add on is standing by for as long as it takes you to again run out of included outgoing minutes. Virtually everyone with the $15 plan and only 100 minutes of outbound calling should spring for this because you just know it is going to be extremely inconvenient when it happens!
Terry
dabr
geopublic
@arunaralhan  Yes, that is exactly what it means.
hairbag1
Unlimited in-coming calls. 100mins of out-bound calls.
