pls help understanding how much data i have for month
duck
Hello,
below is what shows up for my data.
Does that mean i have 2GB together per month? I thought I only had 1 GB together..
What's the 1GB Promo?
Thank you! I just checked it today.
NameData Limit* (MB)Data Used** (MB)Remaining Data (MB)Status
1GB Promo1024275.544748.456Active
500MB + 500MB at 3G Speed1024356.790667.210Active
ShawnC13
@duck wrote:
Hello,
The promo was probably one of the times PM gave data to everyone.  You have the 1GB in your plan data every 30 days and the promo data will be used if you run out of plan data in your 30 days
 @duck
The 500 + 500 is your plan data. That 1Gb is _probably_ an add-on.
At renewal, your phone will use your plan data. If you finish that then it will move on to any add-ons. Then you renew again and it will go back to the plan data leaving the add-on data waiting. When comes the day that you use your plan data and any add-on data then your data stops.
hairbag1
@duck wrote:
Hello,
Your regular $25 Plan data still has 667.2MB's while you also have 748.5MB's Promo data in reserve in case you run out early.
The Promo data will roll over each month until you use it up.
