09-25-2019 05:28 PM - edited 01-05-2022 07:16 AM
Excuse me,I have purchased the plan cost 15 dollars including the 400min long distance international contact,however,when I try to call my friend in China, it still tell me that I need a long distance international contact plan.
So what should I do?How to start the plan?
09-27-2019 01:19 AM
login to your account and check if your plan is active, and check if you have any mins to make call
09-25-2019 05:43 PM
I have not add 011 at the first numbers before.Thank U.
09-25-2019 05:38 PM
My plan is the plan cost 25 dollars per month.
09-25-2019 05:37 PM
I have add it.But still can not work.
09-25-2019 05:37 PM
You also need to format the number properly. Here are some instructions from country code.org.
09-25-2019 05:35 PM
@doctorsol wrote:Excuse me,I have purchased the plan cost 15 dollars including the 400min long distance international contact,however,when I try to call my friend in China, it still tell me that I need a long distance international contact plan.
Can you confirm you still have minutes left on your plan (log in to your self serve account)?
And I'm assuming you still have minutes left on the add-on.
Make sure you are dialing 011 - 86 - Area Code - Phone Number
09-25-2019 05:33 PM
Which plan do your have?
You need a plan with call minutes before you can use minute add-on.
09-25-2019 05:32 PM
You should be able to call China if you have that add-on. Can you check to see that the add-on shows in your self serve account to start.
