long distance add on
chip13
When I try to call long distance to the US a recording tells me I do not have an active add on.  When I go to add ons the long distance add on appears on my account.  Please advise!
7 REPLIES 7
@chip13
Its an honest mistake. Contact the moderators and ask them to exchange the add ons. Its not guaranteed that they will ( nor dó they have to?) but they most likely will....
popping
@chip13 wrote:
How do I eliminate this problem?  Is there an add-on that includes all US rea codes?  When I purchased I was led to believe it covered all the US.
You need to read the note #4 of the Terms and Conditions at the end of  Plan and add-on page.
That one does not include the US. You need the 1000 minute US one. Same price.
chip13
rebooting did not work.  A little bait and switch?  I looked at my add-on and it says 300 minutes of international access.
popping
@chip13
Reboot your phone may fix the issue unless you are phone the phone number falls into the area listed in @Triguy post above.
chip13
Triguy
Do you have the $15 add-on and not calling the listed area codes ?
1000 U.S. Long Distance Minutes - $15
Calls made to numbers starting with the following six digit combinations are not included in US calling from Canada and will not be completed when dialled: 712-432, 605-562, 641-552, 605-475, 605-477, 712-775, 559-726.
