11-20-2019 12:09 PM - edited 01-05-2022 08:03 AM
11-20-2019 12:24 PM
@lg1475 wrote:hi
i am in toronto ,but i am not able to send international text (India) it always says error 38
Try both 011 and + as suggested. Are you using the country code 91?
11-20-2019 12:19 PM
@lg1475 wrote:hi
You always need an exit code from the country you're in to get to another country. Then you always need a country code to select which country. Then whatever the other end phone system has for dialing. We have area code and prefix here before the final 4 digits. The US and Canada are regarded as the same country in the global telephone system. The other option is to use + in front of the country code instead of 011.
And finally of course that your recipient can receive international texts.
11-20-2019 12:12 PM - edited 11-20-2019 12:14 PM
@lg1475 wrote:hi
Make sure you're dialling the proper international codes to where you want to text to.
