06-18-2021 09:36 AM - edited 01-06-2022 02:33 AM
hi there, I am moving to Europe for a few months but want to keep my phone number. is that possible? Do you have international plans for roaming?
06-19-2021 02:50 AM
You can recieve 2FA codes via a phone call vs text message. This gives you two options to recieve them. You can keep your sim card/plan active and call forward your pm number to your fongo number before you leave then remove the sim card and leave it somewhere safe in Canada. Fongo works on both wifi and mobile data. Once you have a local sim card you will be able to stay connected to your pm phone number
Alternatively you can suspend your service via lost/stolen in your account before midnight eastern on or before the evening before your renewal. This will keep your voicemail active. You could then call your voicemail from another phone number (ie. your fongo number) and press * when it connects and enter your 4 digit voicemail pin #. You can then retrieve voicemail messages and verification codes.
06-18-2021 09:06 PM - edited 06-18-2021 09:08 PM
i wouldn't bet on Fongo's SMS.. while it can receive SMS and some short code SMS.. it does not receive all those, esp from Banking for 2FA.. it might not might not work.. in other words.. not reliable at all.
So, i guess for OP, this might not be a good choice unless OP can switch to using Authenticator app as your 2FA rather than SMS.
06-18-2021 08:04 PM
@softech Would porting to Fongo help with the 2FA texts the @16victoriaevans gets? I think that was a big part of why there's a need to keep the number active/roaming.
If loyalty and plans aren't an issue, I would suggest @16victoriaevans porting the number to the TextNow app to still receive SMS messages (in Europe), then port the number back when returning to Canada.
06-18-2021 07:14 PM - edited 06-18-2021 07:14 PM
@16victoriaevans how long you will be away from Canada?
If it is long enough, maybe it worth to consider porting to Fongo first for $25 one time charge. You can then port it back to PM when you are back in Canada. As long as you stay with Fongo for 90 days, it is free to port out
06-18-2021 07:07 PM
@16victoriaevans wrote:hi there, I am moving to Europe for a few months but want to keep my phone number. is that possible? Do you have international plans for roaming?
If you are planning to come back, and want to keep your phone number, then maybe you can
But if you are not coming back, I do not see any reason to keep this number active as you cannot use your Public Mobile plan outside of North America.
Unless you have someone in Canada that can manage your phone number on your behalf.
06-18-2021 01:42 PM - edited 06-18-2021 02:05 PM
All Tier 3 providers do not have great roaming option. In fact we are lucky PM offers US roaming, I think Lucky does not even have this (Lucky customers are not as lucky as us 🙂 )
For Europe, it's definitely cheaper to get a local SIM for data and calls.
I understand you would like to keep the service in Europe for 2FA, you might have to see if your services have other 2FA option , like Authenticator app instead of SMS. In fact, using Authenticator app is safer than SMS , too
06-18-2021 01:32 PM - edited 06-18-2021 01:33 PM
@16victoriaevans : You're not the first person to ask that. All Public Mobile services work only while in Canada. Inbound texting works in the US. Other services in the US require roaming add-ons. Otherwise...nowhere else.
06-18-2021 01:14 PM
the reason I want to keep the number available to me overseas is because of the apps and programs that send verification codes to my cell number. will I still be able to receive text messages internationally as it mentions in this package for the $15 plan?
"International Text and Picture Messaging"
06-18-2021 01:13 PM
06-18-2021 10:47 AM
06-18-2021 10:20 AM
As others have said, the only roaming package available is to the US. However, here's a creative idea if you're a bit more tech savvy...
Get a local SIM when you get to Europe - it's cheaper and they're quite accessible, whether at the airport or elsewhere. Then, you can set up a VoIP account and forward your Public Mobile number there and still receive calls (albeit over VoIP data) when you're in Europe. 🙂
06-18-2021 09:44 AM
Public mobile does not offer international roaming except for the United states (10 day roaming packages). Best to buy a domestic SIM card/package when you get to Europe.
A few ways to keep your account active while you are away. Check this thread;
06-18-2021 09:40 AM - edited 06-18-2021 10:33 AM
Unfortunately, PM only offers roaming in the US.
You could Wi-Fi apps like Textnow, Skype, Signal, or Fongo. To keep your PM active , you could keep the $15 plan.
