10-31-2018 06:34 PM - edited 01-05-2022 02:22 AM
10-31-2018 07:03 PM
Welcome to Public Mobile @zazbot420
It has been mentioned on here on the forums quite a lot. The recommendedn website to check if your phone is likely to work is:
Hope that it helps.
There are some models that supposedly won't even work on the Public Mobile Network even if it's unlocked because of the frequencies the phone is capable of.
10-31-2018 06:53 PM - edited 10-31-2018 06:54 PM
If you read through the forum you will find many instances of phones from China missing the nessiary band causing limited or no service.
Edit this is just one example
10-31-2018 06:48 PM
I am using a phone from China and it works fine
10-31-2018 06:46 PM
@zazbot420 the phone can be locked to Telus or koodo.
Also not all unlocked phones will work. Only phones that have the frequencies that Telus supports.
