add ons 400 min
JSch
I purchased 400 min Intl. Long Distance calling and I can see it as active under my self serve profile, but when I'm trying to make a call to Germany I get "voice is not included in your plan"
14 REPLIES 14
dabr
@JSch wrote:
I restarted the phone and it works now 🙂 THANK YOU!!!
@JSch   Good to hear and thanks for updating us 😊
JSch
dabr
@JSch wrote:
I'm dialing the correct number because I called number before from this phone with different provider SIM card. The issue is: it is telling me "voice is not included in your plan" but I purchased the add on and it is showing on my account as active. I don't get it!
@JSch  Try rebooting your phone or removing the SIM for a few minutes and reinserting and restarting the phone.
@JSch  Are you sure the number didn't change? Can you try calling another number in Germany?
JSch
geopublic
@JSch  If you have an active International calling add-on and get that error it's because there is an error in the number when calling.
mimmo
Try +49 then number
@JSch  An exit code is the code used to dial out of your country. Stay safe
JSch
yes I dialed that 01149163...
@JSch wrote:
What's an exit code?
before you dial their number
dial 01149 -(then their number)
011 is the exit code
49 is the country code
JSch
Naepalm
How to call Germany from Canada:dial 011 + 49 +
You need to dial this before the phone number 01149+ the number you want. That's what I found when I looked at how to call Germany from Canada.
edit: beaten to the punch while searching LOL @JoyLuck @NDesai
Hope this is helpful.
JoyLuck
Are you doing this to make the call:
To call Germany from Canada, dial:
011 - 49 - Area Code - Land Phone Number
011 - 49 - 11 Digit Mobile Number
  • 011 - Exit code for Canada, and is needed for making any international call from Canada
  • 49 - ISD Code or Country Code of Germany
  • Area code - There are 5197 area codes in Germany. If there is an area code dial area code of the city in Germany you are calling after dialing ISD Code. If there is no area code dial the Recipient's Telephone Number after ISD Code.
NDesai
@JSch Are you correctly dialing exit code + country code + area code + phone number? Make sure your phone is not blocking any international calls.
