Wrong Add On purchase in Error
manolo1881
Purchased wrong add on
9 REPLIES 9
tabi159w
The only way to change an add-on is to contact a Moderator. Good luck!
popping
@manolo1881 wrote:
How can I transfer to right add on
PM is prepaid service.  There is no change after purchase.
Only moderator can access your account.  Create a moderator support ticket for help.  There is no guarantee for the change.  YMMV.
Benjaminsfc
Click the ? on the bottom right corner and chat with SIMon, the Public Mobile chatbot : A mod would have to look into that for you!
Be Very careful next time as thats never a self serve fix
@manolo1881 wrote:
Bought wrong at on in error I intended 2 purchased an international talk plan hey I ended up purchasing a kind of that us talk plan how can I change that
@manolo1881 contact the moderator  click the ? bottom right corner to contact the moderators ask Simon the robot to speak to a human to generate a ticket mention wrong add on check envelope top right for a response time is between 2-48 hours
Contact the Moderator Team (Public Mobile representative) for assistance:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work
manolo1881
manolo1881
gpixel
@manolo1881 contact moderators here and ask them to change it for you
make sure to check your inbox(top right corner envelope icon) periodically, for a message
