Reply
Re: When I try to make calls my phone says that I need a long distance add on
@Rascal wrote:
@Carld123 wrote:
@Rascal
Where are you traveling?..
United States. So I just tried calling home, but again, I was told that my plan does not include an add-on. Could I get a moderator to reply please? If I can't call anyone, I would like a refund for my add-on.
@Rascal
Sounds like you also did not purchase the correct add on...must be a roaming add on
I'm not sure how to attach moderator team to this thread. Can someone tell me how to do that?
Anyway, apparantly we purchased the wrong add-on. Since I have unlimited talk anyway, buying an additional 200 minutes is useless to me. I should have purchased the US roaming talk.
Is there any way to cancel the add-on that I can't possibly use and replace it with the correct one that will be beneficial to me while I am in the United States? If there is a moderator reading this, please reply.
here you can write a message to the moderator.. @Rascal
good luck..
Many thanks to @Lieux and @Carld123 for helping me out. I appreciate those of you who always reach out when I need help. I now understand the difference between the various add-ons and thanks to @Lieux, I have sent a private message to the moderator team. You guys are awesome!
Welcome @Rascal...patience now....Smiley Happy
@Rascal @NINGENZA FYI: You posted to an old thread. In future you will have more assurance of quick help by creating your own topic on the forum, or, if appropriate, sending a private message directly to the moderators.
Refer to the following knowledge base link for information on contacting the moderator team.
>>> ALERT: I AM NOT A MODERATOR. JE NE SUIS PAS MODERATEUR.
I learned something else today. Thanks @NINGENZA!
