What does it mean by "Unlimited Canada & U.S minutes"?
zaidahmed
So I was thinking of upgrading to the $50/30 day plan and it said "Unlimited Canada & U.S minutes". Does that mean I can call anyone from Canada and U.S or will I get coverage in the States?
@Lyang  you can call anyone Canadian and US number from Canada like a local calls, no charge.
this is only included in the $50 or $70 plans
**  "Unlimited Canada & U.S minutes" does not mean you can call it for free when you are in USA.  You will need US roaming Add-on if that is the case
karen-hurst
it means that you can call any Canadian or US phone number form Canada.
Lyang
Good to know
Yes, as @JK8's already posted your device must be in Canada to be able to call to North America (Canada and USA).
BUT - If you travel to the USA, with any Public Mobile plan, you will require a roaming addon (these last 10 day intervals) if you want to use your Public Mobile services. So this $50 plan is no different in this regard.
is mean minutes Unlimited can call anyone in Canada & U.S
out calling and incoming calling include in your plan Free,
and not coverage in the States you have to buy add-on US Roaming
10 day packages, when you are in USA you can make call to canada and U.S
JK8
As long as you are in Canada you can call anywhere in Canada or the US.
