Reply
Highlighted
Unlimited 10-Day Talk/Tet US Add-On
Hi, I have bought the $15 bundle for unlimited talk and text in the US for 10-days, but it does not seem to be working. I also ended up buying it twice in the process. I am really confused as to how it works. Does my phone inform me to when it applies and is it just charged to my end of 30-day plan? Thank you in advanced!
Highlighted
Re: Unlimited 10-Day Talk/Tet US Add-On
It shouldn't be possible to buy it twice, so you probably hit a bug. If you buy 2 US roaming addons at once sometimes it causes them both to fail. You will need to contact a moderator here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Highlighted
Can you see in your history of payment that you was chargerd for @Yavell?
Highlighted
@Yavell When first you went to buy the US add-on, you probably added the funds to your account. Then the 2nd time, you used the available balance to pay for the add-on. This is the correct way to purchase the add-on. Go to plans and add-on page and see if that add-on shows up there.
_________________________________________________________________________
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Highlighted
You have to see that your payment went through and that you bought your add-on...a message would told you that...
Highlighted
Okay thank you. On the "Plan and Add-Ons" page, it shows the "US Roaming - Unlimited Talk (10-day)" twice. So I am not sure.
Tags (1)
Highlighted
In that case, review your payment transaction detail on your credit card and in your self-serve account to make sure you were charged once.
Highlighted
You will need help from the moderator like said above... sorry @Yavell
Highlighted
HI,
Do you see AT&T or another american mobile service showing on your phone?
You may need to restart your phone and or reset network settings to force it to look for the american carrier.
Highlighted
@Yavell this is your problem.  Both of these two add-ons do not work when there are more than 1 instance at the same time, unfortunately.  You will need to reach out to the moderator team via private message for help.  To learn how to do so, please see How to Get Help.
