Reply
Highlighted
Unable to place acall
Prompt and message claims that I had used up my minutes! I am on $ 15 Plan.
Purchased add on yesterday for 500 Canada wide calls. Still I cakeep getting voice
prompt saying i can not make calls!
Please help
Highlighted
Re: Unable to place acall
Are you certain you actually bought the add-on? Very often it is done incorrectly leaving you with the $5 you added just sitting as available funds. it is a convoluted process where you have to add the required funds and THEN select the add-on. Most select the add-on and then add funds which leaves the $$ sitting as unused available funds. Check and see.
AE_Collector
Highlighted
Please help
Did you top up your account by $5 first or have a balance of at least $5? Then you buy the add on.
Highlighted
@dinkle  Dial 611 and verify that you have the add-on added. If not, just try to purchase the add-on again and it should work.
