Reply
Re: USA Add On's
@Gerry_P wrote:
I've already added the required funds. I was planning on choosing the add on (talk/text/data)  just before I get on the plane to the USA. That way, when I land the phone should work, correct? Or are you saying I have to call 1-855-478-2542 in order for it to start working?
Correct.  Purchase the add-on.  Restart your phone after you arrive at your destination. You will be connected to AT&T or T-Mobile nectwork.
Re: USA Add On's
You can activate the add on via the website OR by calling 611 or that 855 #. Your choice. Once in the US, without WiFi, 611 or the 855 # becomes your only choice. If you activate it the same day its no different in the end.
Re: USA Add On's
Hey there I'm wondering if the Holiday bonus ADD ON is roaming friendly, or do I have to use this in my home bountry?
***$0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US) ***
Re: USA Add On's
They are both only for use in Canada.  If you are in the US then you would need to purchase a roaming add-on which are valid for 10 days from purchase.
Re: USA Add On's
No roam...can use it while in Canada
Re: USA Add On's
No, that add-on is for calls placed *from* Canada *to* specified international countries (including USA)
Re: USA Add On's
No, only from  in Canada.
