Showing results forΒ
Search instead forΒ
Did you mean:Β
Reply
Highlighted
USA Add On's
Hey Peeps,
I'm heading to the US on Thursday. When I add funds to my account for the US talk\text\data add-on is it just $20 or $20 + HST?
Thanks,
Gerry 😊
Accepted Solutions
Highlighted
Re: USA Add On's
@Gerry_P wrote:
Hey Peeps,
Thanks,
Gerry 😊
You need to add $20 to your availabe funds. Your credit card will be charged $20 + taxes.
All Replies
Highlighted
Re: USA Add On's
@Gerry_P
$20 + tax
You pay tax when you add fund to your account.
Highlighted
Re: USA Add On's
@Gerry_P wrote:
Hey Peeps,
Thanks,
Gerry 😊
Highlighted
Re: USA Add On's
@Gerry_P   all prices are plus gst.
when you add 20 you pay 20+ taxes  but it only shows as 20.
Highlighted
Re: USA Add On's
Awesome, thanks for clarifying that. I'm a newbie with PM 😏
Highlighted
Re: USA Add On's
Also wait until the last possible moment to add it.  The 10 days start when you buy the add on.
@Gerry_P wrote:
Hey Peeps,
Thanks,
Gerry 😊
Highlighted
Re: USA Add On's
The US Roaming add-ons are good value. Once you purchase one, it will last for 10 days.
Regarding US Roaming add-ons that include SMS text, you should know that after the roaming add-on expires, your incoming text messaging will stop working for 24 hours. This is a long-time bug that Public Mobile has not yet been able to fix. Once you return back home, you can contact Moderators so they can reenable your texting (remove the roaming add-on) to avoid the problem.
Highlighted
Re: USA Add On's
Similarly, I've had a few technical issues throughout the eight or so days when I activated my U.S. data roaming plan.  Full of so many glitches, though, due to its simplicity it seems well suited for a very short stay.
But whenever I need to be in the USA for a longer time I will do as two friends have just done, which is to buy a local SIM card after arriving in the US and use that for the 11-30 days you might be there. Not just that it may be cheaper, but the service (they report) will be glitch-free.
Highlighted
Re: USA Add On's
Calls to 611 or 1-855-478-2542 will work in the US without an active roaming plan. You could add the funds to your account for the desired roaming option prior to departure, then once in the US call one of those numbers to activate the add-on on the day of arrival.
Option 2 - buy add-on
enter 4 digit account pin
Option 3 us roaming add-ons
Select choose of these us roaming 10 day add-ons:
1. Talk+Text+250mb
2. Unlimitd talk
3. 250MB data
4. 500MB data
5. 1GB data
6. Unlimited text
Highlighted
Re: USA Add On's
I've already added the required funds. I was planning on choosing the add on (talk/text/data)  just before I get on the plane to the USA. That way, when I land the phone should work, correct? Or are you saying I have to call 1-855-478-2542 in order for it to start working?
