US talk and text plan
karatebarb
After purchasing US talk and text how do I turn it on
geopublic
@karatebarb  Here is a good reference:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/U-S-Roaming/ta-p/307883
ZfromVanC
U.S. Roaming Add-ons are enabled a soon as you buy them. With the US add-ons, you need to connect to the roaming partner networks (AT&T, T-Mobile) in order to use the service. Make sure you enable roaming on your phone.
RossN
the good thing about PM is that you can leave roaming on all the time since there are no roaming charges
Alex888
@karatebarb It starts automatically, but your phone needs to have roaming on. Make sure that it shows up under your addon sections in your account.
dabr
Make sure you enable roaming.
RossN
it should be on now you don't have to do anything else does it show up in your add ons?
