US roaming add on does not work on iPhoneX but works on Android
kmartynov
Got us roaming add on and I'm in US. I have iPhoneX and neither text, nor data nor voice work on it. Roaming is enabled. I inserted public mobile Sim in android phone and it works OK. Any idea how to make it work on iPhone? I restarted it few times already - no luck.
Thanks.
glad it worked for you iphones can be a pain I know I use one ha ha
Chipster
Just an FYI. I read somewhere the Public Mobile's US partners are AT&T and TMobile.
kmartynov
I fixed it by manually selecting ATT under carrier.
geopublic
Thanks.
@kmartynov  Did you try resetting your network settings?
Touch Settings.
Scroll to and touch General.
Scroll to and touch Reset.
Touch Reset Network Settings.
The iPhone will reboot. Once it turns on, the default network settings will be restored.
