US data add on not working
gblackburn
Hello, I have added US data to my plan (which I have done multiple times before) and it's not working this time.
gpixel
@gblackburn
  • enable/disable airplane mode
  • try turning off your phone, remove your sim, turn on the phone and reinstall
  • reset your network settings
contact customer support mods if you are still experiencing issues
type "data troubleshooting"
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a response
@gblackburn if you are in the US enable roaming and restart your phone. Stay safe.
shep22
@gblackburn hi if you mean the 10 day roaming data you need to be in the US to use it
hairbag1
Not sure which add-on you're talking about. If it's the 10 Day US Roaming data add-on...you need to be in US for it to work.
Log into your account...do you see the $$ sitting in Available Funds. If so...you need to go back and buy the add-on you want.
Restart phone.
