US calling rate
mhamed
Hi, I wanted to know what the rate is for calls to the U.S. if I don't have a US add-on for my plan.
Thanks!
@Samianauman wrote:
Also another alternate is if you have a data plan you can download hangout dialer you can use your data to call USA doesn't use lots of data I personally use that app also work with WiFi and best part your public mobile will show as a caller ID as well try that if you don't want to add add-on
When in the US, add a google voice number to the google account to make receiving calls from the US callers a little lighter on their pocket book.
kav2001c
@mhamed two prices
$8 for 200 mins = $0.04 per minute
$15 for 400 mins = $0.375 per minute
Thanks!
There is no rate without a long distance add-on.  The calls just won't work.
** I am not a Mod, please do not include any private info in a private message to me.**
mhamed
Thanks very much.
Watoko
$0. It simply just won't work. Since Public Mobile is a prepaid service, you will need to grab an Add-On to be able to call to the US.
Beauty is you don't have to worry about extra charges or surprising fees. You get what you pay for.
