02-05-2020 11:22 PM - edited 01-05-2022 09:22 AM
02-06-2020 12:12 AM
@robinraman2002 wrote:Do we have a number to contact moderator or some kind of customer service?
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking the icon below:
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
02-05-2020 11:52 PM
@robinraman2002 wrote:Hi,
While adding my US talk and text plan.
I made a payment for one add on because it wouldn't let me add otherwise even though i am on Auto Pay.
Then while checking my add on, I accidentally added the same Ad on again.
Can moderator please fix it ?
So I tried this out (without purchasing). Are you saying you went back in to Purchase Add-ons after having purchased an add-on and actually bought the same add-on and it let you? Because going in once, you can only select one add-on once.
02-05-2020 11:48 PM
@robinraman2002 click the "?" in lower right side of the page, type "contact moderator", and follow directions OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-05-2020 11:42 PM
This is the "customer service". For actual account issues you need to contact the moderators using the ? balloon in the lower right (if it shows).
When you click on Plan Details, what do you see under Add-ons part way down? Or if you bought data add-ons do you see it (them) under add-ons on your overview page?
02-05-2020 11:36 PM
02-05-2020 11:26 PM
@robinraman2002 Check the balance on your account. Do you have the extra funds there? You cannot purchase two at the same time. It's a two step process. First add funds then choose and purchase the add on. Remember US roaming add ons start right away.
02-05-2020 11:25 PM
I had understood that we can't buy two of the same add-on.
But anyway, yes, you discovered that autopay is only for renewals. You need to deposit money to then buy add-ons.
You'll need to contact the moderators.
