US Talk add on
MCTIERNAN57
I purchased a US talk only add on for the $8.00 for 10 days and it is not working. I assumed from the description from Public Mobile that my phone would work for calling while I'm in the U.S. ????
8 REPLIES 8
There is also a an $8 long distance minute add-on. Is it possible that the wrong add-on was selected by accident? What's the name of the add-on shown on your account page?
PAULRANG18
Firstly, check to see if the plan has been added to your plan and add ons. If not you will have to add it. Reboot phone and enable roaming when at destination. Choose one of US mobile carriers.
@popping wrote:
Enable roaming and restart you phone after arriving at your destination.  You will be connected to AT&T or T-Mobile.  If not, manually select one.
I believe the roaming toggle is just got data.  OP bought a calling only add-on.  Making sure that there's a converting l connection on the roaming partner network should be sufficient to make phone calls.
popping
@Triguy wrote:
Log into your self serve account and check under data and add-ons to see if it is listed.  If not then make sure that you purchase and added it.  Here is more info.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
Correct.  Buying add-on is a 2 steps process.
1.  Add fund to your account
2.  Purchase add-on.
Then, verify that the add-on is added to your account.  Enable roaming and restart your phone when you arrive at your destination.
LovesToPM
@MCTIERNAN57
Purchasing Add-Ons is a 2-step process:
  • You will need to add funds equal to the amount of the Add-On to your account.
  • Then, click on ‘Purchase Add-Ons’ on the Overview page.
More info available here:https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974#M22...
Triguy
popping
gblackma
Have you enabled roaming on your phone @MCTIERNAN57 ?
