02-10-2020 01:03 PM - edited 01-05-2022 09:26 AM
Hi Community
I am going to the US in a month. My current plan has 2 G Data, unlimited international calling, unlimited texting.
My question is what should I purchase as an add on. I'd like to use data, talk and text. Do I select the $20.00 250mb Data, unlimited talk and text package?
Thanks
Chris
02-10-2020 01:15 PM
Thanks for your help
I appreciate it.
Chris
02-10-2020 01:14 PM
@jackson5240 wrote:Thanks
So to be clear, the 2G of data that I normaly have on a monthly plan here in Canada will not be valid in the US?
I will only have 250mb of data not 2.25G of data. Sorry for newb type of question.
@jackson5240 that is correct unless you purchased the plan that was offered last summer that was a Canada/US plan that is the only plan that would work in both countries without the add-on
02-10-2020 01:12 PM
Thanks
02-10-2020 01:12 PM
Thats the one I get usually aswell, I typically download google maps so I can use offline. And then switch data on off as needed.
02-10-2020 01:09 PM
@jackson5240 wrote:Hi Community
Thanks
Chris
Hey Chris, that is the package I get when I go to the states. It isn't a ton of data but wifi is pretty much all over the place now.
02-10-2020 01:07 PM - edited 02-10-2020 01:08 PM
The bundle would suit your needs. Keep in mind that the roaming add-on is valid 10 days from purchase. Make sure you purchase and add it to your account.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
