05-17-2019 07:51 AM - edited 01-05-2022 04:58 AM
I ordered a US Roaming package on May 16, 2019. My transaction history shows that the debit charge was applied to my account and it also shows a second transaction with the package applied to my account. Under my plans/add-ons I can't see the US roaming package applied and as a result I'm unable to use my phone in the US currently. Looking for some help on this one since I'm unable to use my phone.
05-17-2019 09:07 AM - edited 05-17-2019 09:07 AM
@kathycahill wrote:I ordered a US Roaming package on May 16, 2019. My transaction history shows that the debit charge was applied to my account and it also shows a second transaction with the package applied to my account. Under my plans/add-ons I can't see the US roaming package applied and as a result I'm unable to use my phone in the US currently. Looking for some help on this one since I'm unable to use my phone.
@kathycahill While waiting for the moderators to respond, the fact that the US Roaming add-on does not show on your initial page when you login means that the add-on was not added to you account.
Here is a detailed step-by-step article on how to purchase a US Roaming add-on for your review. It shows what the landing page should look like if you have followed all the steps.
Hope this helps.
05-17-2019 09:02 AM - edited 05-17-2019 09:06 AM
Do you have any and all roaming options on? Did you manually scan for and find and connect to either AT&T or T-Mobile? Did you get a text from Public Mobile welcoming you to the states and suggesting to buy add-ons? Did you restart the phone?
Edit: when you click on Plan details in your My plan area, does it perchance show up in there?
05-17-2019 08:55 AM
To be clear the funds have been applied and I have a 0$ balance. Transaction history shows that the roaming bundle was purchased.
05-17-2019 08:04 AM
@kathycahill, this is the definitive guide on add-on purchasing.
05-17-2019 08:02 AM
@kathycahill @geopublic is right ...if you still see your payment in your avaliable funds it's because you didn' t apply it for your add-on yet...click on buy an add-on.
05-17-2019 07:59 AM
Purchasing Add-Ons is a 2-step process:
05-17-2019 07:55 AM - edited 05-17-2019 07:55 AM
In this case you will need help from the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and ask them to help you...waiting time is few hours to 2 days.
