09-18-2017 02:46 PM - edited 01-04-2022 02:38 PM
09-19-2017 09:43 PM - edited 09-19-2017 09:48 PM
On the first computer I was using, I didn't try another browser nor did I clear my cache. But I did find that 3 of 4 family accounts show the US Roaming options and one doesn't.
On a second computer, I get the same result for the same accounts.
All are using Chrome.
Update: I was also able to try it via Firefox. Same result. There seems to be something wrong with one of the accounts (yesterday it was at least 2 accounts).
Rob Wood
09-18-2017 09:29 PM
09-18-2017 05:09 PM
09-18-2017 05:08 PM
09-18-2017 03:14 PM
While you're waiting, try again after clearing your browser's cache and turning off any popup/ad blocker, and/or try a different browser (Chrome often seems a cure).
09-18-2017 03:10 PM
Is there anything else odd with the account? Not that it should matter, what plan do you have? Anway, the option should be right there. If you need help with adding the service, you could contact the moderator team for assistance. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team. Good luck.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
