Reply
UNLIMITED Incoming calls?
My $15 plan is as cut and pasted below.
  • 100 MINUTES Canada-wide talk
  • UNLIMITEDIncoming calls
  • UNLIMITEDInternational Textand Picture Messaging
  • + BONUS 250 MBData⁴at 3G speed with AutoPay
  • VOICEMAIL& Call Display
Does UNLIMITED Incoming calls mean that voice minutes are not used up if I receive a call from an another cell or landline phone?
Re: UNLIMITED Incoming calls?
Yes that is exactly what it means.
Just to make sure  --- are all incoming local and long distance calls free regardless if they are from another cell or landline?
Yes
Yes
WOW...WOW !!!!!  So glad I ported from Bell Mobility to Public Mobile.
Yes
Sory for yet another question -- Cut and pasting from my account page - there is no mention of the unlimited incoming calls.
100 minutes Limited Canada-Wide Talk      14  /  100 MIN
250 MB at 3G speed         44.007  /  250 MB
Unlimited International Texts   132  /  999999 Unit
Yes
This is a known issue. Public Mobile is working to add the Unlimited Incoming calls to your plan description.
Not sure if you will see a separate line for it on your account page though.
A simple test to know if it's working, your 100 minutes of talk counter will increase only for out-going calls.
Yes
Don't worry about it unless incoming calls start using some of your 100 minutes.
@Beer, which day did you set your plan change (or activate) the $15 plan?  The original $15 in mid-to-late April did not include unlimited incoming calls.  The late April updated $15 plan replaced the original, and didn't show a difference in 'plan' description (yet), and is currently being addressed by PM.
If you have very recently changed, you might be on the unlimited incoming plan. When did your latest cycle start?  This would help confirm.
GR
Mine was set to change this morning at renewal and it did no problem!  I can confirm that the incoming calls don't go in the 100 minutes counter on the account page. As for the wording on the plan it still does not say unlimited incoming calls. I switched from the old 15$ plan to the new 15$ plan and everything works great
